Root Losing Root and now USB giving me issues???
So I went into Titanium Backup and couldn't gain root access. tried intalling busybox again and updating SU but no luck. Now when I connect the USB to my pc it will link up for about 15 secs then no connection? Any ideas?
The standard super user and updated SU wont work. You HAVE to use the one including in the root script.
Get it connected with USB debugging and rerun the script.
Ok Ciper,
My phone will only momentarily connect. I have tried this on 3 pc's so far. Any suggestions?:confused:
I have not received the update but is really worrying me as I need tethering to download contract and sign off sheets to my iPad. If this becomes I problem I will have no choose but to go back to one of the big 4.
I always have trouble connecting my phone. Sometimes using another USB port helps but that port can only be used once and then I have to use another. Im now out of ports and so its a bitch to connect to the PC.
