MorpheusX3
Member
So recently I ported my number over to Google voice, because while I always had a reliable 3G connection, I wouldn't always have reliable calling and texting. For Google voice to work though, you need to deactivate your plan, and have it reactivated. OK. Done.
So I wake up this morning and turn on my phone, ready to reflash all of the custom firmware I initially put on it (because I had flashed a stock RUU before reactivation) and I thought, I should probably test everything out before I go on.
I go to try out Google Play (to download an app) and it says I don't have connection after a couple seconds. Now this is strange, because I have the little 3G up top. Along with that, it will place calls.
Now I'm well aware of the spotty connection you get with this service, but with this, I tried to open up the browser, and the Virgin Mobile site fully loads. (pretty fast too)
So I go to google, it redirects me to the Virgin Mobile site, again and again and again. Using wifi I tried to download the Speedtest App. On 3G I would consistently get "network connection error." And it wouldn't be able to connect.
So what do you guys think is up? I tried the updated radio and PRI, but they didn't help. So what should I do? Is there a specific fix? Or is Virgin Mobile going to get another call for a network reset?
:shot:
:shot:
(no homo btw)
