D
Deleted User
Guest
I can't connect to my mobile network.
If my APN Type is *, then the 3G symbol shows up in my status bar but I still can't use internet at all. My browser won't load, my apps won't load.
If my APN Type is mms, then in Settings, the mobile network just shows disconnected.
I've tried switching my phone to airplane mode, turning the phone off, then on and then switching off airplane mode but it doesn't work.
Is it my SIM card that has issues, or is it the phone? Cus the phone is still new.
Anyone out there experiencing the same problem or has a solution???
