Lost charger
I lost my mobile charger for LG G2 so I tried to charge it with HTC charger but it was charging very slow and the charger was overheating. 1st question: Why my HTC charger isn't suitable for LG G2? 2nd question: Which charger should I buy(which specifications to look for)?:confused::confused:
You might want to read my post in this thread.
http://androidforums.com/lg-g2/839786-using-generic-3-chargers-ebay.html
Likely either the charger's output voltage or current is out of spec, or the cable you were using isn't capable of fast charging. Too many variables really.
The link I provided in that thread is for a VZW US model. If you are located somewhere else, then the specific model will be different with a different plug to go into the wall.
I would stick to an OEM charger. If you still have your OEM cable, then you can get what you need a little cheaper. The one on eBAY I pointed to comes with the cable.
Good luck.
The charger that Verizon sells assuming u have a Verizon G2 charges fast that is the one I use since a squirrel ate my charger.
