I rooted my 2012 Nexus 7 (4.4.4) this morning using the Wugfresh Nexus Root Toolkit v1.8.6. I backed up my device using the toolkit. The "Backup Virtual SDcard" option wasn't available to me as the device needs to be wiped first if running 4.4.4. Too bad, as according to the toolkit, this backup method was the "highly recommended" way of backing up. Other options were to backup single apps, or create an android backup file. Options in this last option where to include "system apps+data", and/or "shared data". These last two options were not recommended in the help file. SO... I just used the "Create Android Backup File". That must have been my mistake. I thought this backup would backup my docs and pics. It doesn't appear to have done so. When I click on the restore button, the *.ab backup file supposedly restores... but I do not see my docs or pics anywhere.*
Stupid me!! I should have just copied those files to my computer and then transferred them back to the Nexus 7. Is it possible that I'm wrong, and that my data is residing somewhere on the device? If so, how do I enable this data? I'm afraid I know the answer. If the "restore" simply restored a bunch of cr** I don't need after the rooting, I'll just wipe the device and start over, sans my lost data. Any chides, tips, or chuckling is welcome! Thanks!
