Help lost my pattern lock
Hi - I have a new droid. I set it up with a pattern lock. Worked fine for awhile. Then something happened (I don't know what) and I was forced to put in a 4 digit code - which I did. Now I have to unlock by putting in the code and hitting check. I don't know how to turn this off and go back to my pattner lock. I find the menu for this, but it's greyed out and I can't select.
Thanks,
Mary
Thanks for responding. Not sure how to do that. Under security, security lock type is greyed out so I can't select it (it says passcode lock is turned on). I can change passcode and set the security lock timer, but I can't set it to 0.
Thanks for any further thoughts.
Sounds like you might have added a corporate Exchange account with a mandatory PIN policy. If that's the case you can't disable the PIN lock or the timer unless you remove the Exchange account. An app like Touchdown may prevent your entire device from being locked if that's desired. IIRC, some of the non-stock Exchange apps won't lock your device but will require the PIN to access the Exchange client instead. You should verify this first though.
Definitely keep in mind any recent changes you made when attempting to troubleshoot an issue.
