Lost phone in Airplane Mode - Help!!
kitfox123
I put my phone in airplane mode..then lost it. It is still in my house, I did not go outside. But I am unable to locate it via visual searching.
How Can I find this phone when it's in airplane mode?
Nothing in the link you posted applies to me and I already googled that crap..that's why I'm here.. WHY would you just post a link to a crappy website I found on my own???
I'm not registered with Samsung, I don't have any services turned on...I'm a privacy person. HOW CAN I FIND MY PHONE?
well i'm just trying to help.
i can tell you how to use google's find my device....you can use it even if you have airplane mode. but if you disrespect me like that....i will not tell you how.
maybe some else can explain it to you.....good luck.....BYE:cool::cool::cool:
You did not tell me anything. I'm not signed up for any of the services in that article and I doubt most people are. If you have any other suggestions, pitch it up. otherwise, have a nice life..I'll get somebody else that knows what they are doing to help.
Ciao.
Ciao.
:mad::mad::mad::mad::mad::mad::mad::mad::mad::mad:
edit: ok that was just rude. like i said i was only trying to help. you do not have to be rude about it.
good luck getting any kind of help. i'm sure the help will not be appreciated by this member.
folks move along here nothing to see.
Well if the phone is in airplane mode, and completely off-line, it might as well be OFF. I think you're just going to have to search and find it the old fashioned way. It may start making noises when the battery is running low? Some phones do that.
Unfortunately we're NOT mind readers, and my scrying glass is at the dry cleaners.:eek:
Do you have a metal detector?
As others have said, if the phone's in airplane mode (and you didn't turn on some connection after putting it into airplane mode) then it's an inert object. So replace the word "phone" in your question with "book" or "TV remote" and the answer is the same.
Next time you want help, please don't be disrespectful to others making an effort to help you out. If it's not the outcome your looking for, then just Simply ask more questions without the smart remarks. Members will not want to help with that kind of attitude.
So let's keep this thread to a more calm and respectful discussion. We get your frustration, but don't take it out on the members trying to do their best to help you out.
Ciao.
