Help Lost settings and disappearing storage!
Lars
Android Expert
I've had some settings disappear like losing background live wall paper screen and going back to vzw's.
Also the internal 8gig disappeared once saying it was empty. The same happened to the 2gig sd card. A reboot fixed it but not what I like to see on a new phone.
Anyone else?
i just experienced the issue with the SD Card disappearing
i can clearly see the card in astro
but it is saying it is empty, when i know it is not
WOW, mine said the card was missing. I removed it then put it back in, it worked but that was a strange thing to happen.
as strange as it sounds, i actually had the same thing happening for the first time yesterday, i figured it was because of all the garbage i installed on the phone, but apparently not...
in any case removing and putting back the card fined it...
could it be attributed to the recent os update that went out a few days ago?
Album art grabber, you can use it, then when you reboot your phone, all the images delete themselves.
One time in band camp...kidding.
I put some music on my SD card using the usb cable plugged into my computer When I disconnected the phone from the PC the phone said it was initialized the SD card. For some reason I didn't have any music files on my phone though (using the standard music app). I then replugged it in to my PC and then disconnected it again and this time my phone recognizes all my music.
Odd, I don't know why it happened, maybe the phone just mounted the card poorly on that one occasion.
