When I send my PC books to my Hudl internal memory via USB . After disconnection I cannot find them on the Hudl . Where are they and how do I access them .
I assume you're using a tool to transfer the books?
I would drag & drop then you will know exactly where to find the files. The reader may require the files to be in a particular directory. Search for a file it can read to confirm where that is and drop your files into the same folder.
