justicedealt
Member
Ok, I got two new ones, and I suppose they are running 2.2? Anyway, mine is sucking down the juice. I downloaded Advanced App Killer, but I am not sure what settings it should be on? I only want apps to work when I open them up. The only ones I want running continuously are the text and email apps. Should I be running any of the others continuously?
Also, how do I delete pics from my media gallery, as I cannot get them to drag and drop into a can, and I can't find a delete option. I found save/discard, and discard apparently does nothing.
