Lottery Ticket Scanner
I am looking for an application to scan the bar-code of Canadian LottoMax and other lottery tickets, and then check whether the numbers are in the winner list.
I have found one in Google Play named "Lottery Winner" (link given below). But the problem with this app is, it cannot scan the bar-code, it scans the numbers and then uses a recognition system to translate the picture into digital number. Most of the times the app fails to recognize numbers of the scanned image.
I was wondering if there is any such application!
Link to "Lottery Winner":
https://play.google.com/store/apps/...SwxLDEsImNvbS5pd2luNjQ5LmxvdHRlcnl3aW5uZXIiXQ..
Welcome, I am not sure, I would check in the application section and ask around there, you might get more responses there.
