low available ram
datis
Hi all,
Even though I kill every running application by task killer, 100 M is the absolute maximum amount of free RAM. How could I release more memory to use?
Thanks beforehand.
Menu > Settings > Applications > Manage applications
Then select individual apps based on the biggest and hit the "Clear Cache" button. Some apps use quite a bit of memory -- for example Browser
100Mb is quite a bit anyway, why do you want more?
- Mark
The more RAM you use, the slower the phone gets. Even more than apps running, the amount (and size) of apps you have installed determines how much free RAM you'll have.
Try uninstalling some apps you don't use so much and remember to always do it through the "Market", because if you do it directly in the phone definitions, it will leave the installer behind.
Ok. Thanks for replies. I installed task manager(do you think that's reasonable?) and got 115M free ram. I was just confused because this device should have 256M and I couldn't imagine that system processes and stuff like that could demand that much ram.
RAM is there to be used. Free RAM is actually wasted RAM in a way. I only use a task manager to kill apps if I notice a new app struggling to load. But in general Android seems to do a very good job of managing the memory.
There are apps out there that hog more memory than they should, but that's a different story.
My biggest concern is that there are unnecessary programs running because battery life in tattoo isn't the best possible and extra programs will naturally shorten the battery life. Furthermore, available ram tend to decrease constantly when I use the phone: after a day it has gone from 115 to 75 but I guess that's normal. Rebooting the phone releases that loss again.
