Low Internal Mem , Please Help
I am new to this , but i ll still try to tell you what my problem is . Please Help
I have an HTC explorer . I rooted my phone and then did the adb thing where the phone directly saves the apps to my sd card . The problem now is that even though I have around 15 mbs of internal memory left , and even if I try to install a small file of around 6 mb , it says "insufficient memory available"
What do I do about that ? is there any way where the SD card can be made to work as internal memory ? I have an 8GB SD card , out of which 7 GBs are free . I have searched for the forums , but all the above with "Insufficient Memory Available" queries have been responded to by the procedure that I have done before(ADB one , setting location 2 )
Is there anything I can do to not have this problem ?
I got the partition thing done , but there is a problem now ...
The su command is nt working , I flashed the phone again and put in the ROM . But then when I use Link2SD it demands superuser permissions , and my superuser is not working , it always forced me to quit .
What can I do about the superuser ?
