Also, if it werent too much to ask, how where i to set up ssm mode on a 4gb sd card?
Save anything on your card first to your pc.
Go settings then ctrom then sdparter.
You will slide the top fat to the left, then I would slide the next one down to
1126 or close as you can get it to that. The next one down to 520 or
as close.
Then go back to top and slide the fat all the way to the right. (you should
have a fat and 2 ext4 partitions.
Hit start partition process.
Then go into koumamod and select ssm.
When done, boot back into recovery and formatt sd/ext then reboot and
should be good to go. (It should say like 140-something mb free
and as you add apps it will slowly go down.
Now a 4 gb card is a little small, a 8 would be better.
Data mode would be the same but you would do a fat and only 1 ext4 and
that ext4 would be about the same at 1100 or so.
Then put back what you saved to pc on card.
