Low on Space
shawn10
I have LG Optimus One running Android 2.2.1 I can't install more apps or receive any text messages unless I free up some space. I put a 16 GB SD card in there, and transferred all the apps on there, but some of them won't go and if they do, there's still a small part of the app that remains on the actual phone. Is there a way to install the apps directly on the SD card without having half of it on the phone and half of it on the card?
Thanks!
Part of the app will remain on the phone. I would suggest uninstalling any apps you don't use, deleting texts and call logs will also free up some internal memory
