bigmongo66
I also frequently get the notification "low on space", will rooting my phone and moving apparently to my SD card help eliminate this problem? Thanks in advance. :smokingsomb:
Without root it only moves part of the app data to the sd card(majority of the app and its corresponding user data stays on the phone memory); with root you can move the entire app and its data to the sd card. You need to partition the sd card to do it, but it frees up a lot more space than the standard app2sd.but you don't have to be rooted to use SD storage. not sure why that always comes up. starting with Froyo 2.2, you can move apps to the SD card (the system files that are necessary stay on the user space in internal storage whether you're rooted or not) by going to Settings-->Applications-->Manage Applications--[select app]-->move to SD card
