low phone memory
Hi, I dont understand you: root manual? Try folder All things root, for root advises. With root you can clean stuff you dont want. For more memory have to partition SD card.
Sent from my GT-S5830
Download Update.zip (925 KB). Place the zip on SD Card. Get your phone to recovery mode ( Press and hold Power button and Home button ). Select apply update from SD Card by navigating with the volume buttons. Wait until its over and reboot your phone. If the installation was successful, you'll see an app called Super User on your App Drawer.
Hope it helped. Thanks
