LTE toggle widget for RAZR yet?
OP if the suggested app does what you were wanting would you mind editing the title of your thread and just add (resolved) at the beginning?
"LTE Switch". Works great!
Thankfully free, this program is a shortcut to the Mobile Network Settings where you then select to change between CDMA only and CDMA/LTE. It still takes 4 taps, but that's a lot better than 8.
I'll use it for now.
yar, that's the best there is for now. just like gps toggles - they're just shortcuts to the settings screen where you have your options.
