Willster419
The Casio Smartphone Guru
Identified Problem: The GPS does not work sometimes with the M150 ROM. Most problems are with the "update.zip" files, not the nandroid backups.
Detailed Problem description:
The GPS does not work on a fresh install of eithor of the 4 M150 ROM's
Method(s) to re-create the problem: M150 Rom's (add here)
Install the M150 ROM's
Method(s) to solve problem: add here
Possible Solution:
fixed script problem with the file, "init.qcom.sdio.sh" it existed with all 4 of the ROM's
Status: Seems to have fixed the problem
Notes:
A fix as been to install monkeytools M130 ROM, then install any M150 rom on top of that.
Possible Solution:
Notes:
