jerkwagon
Ok im New to the whole Android thing , but i am excited to finally get on board with a Google phone. I like the iphone, i have no problems with it, its just the new carrier wont work with it. I have 2 macs, Macbook and MacPro (hackintosh) Im am very familiar with computer and how stuff works, I understand 70% of the commands i have to copy and paste from forums to make things work. Right now i am stuck (and im 100% sure its not due to the fact my Desktop isnt legit)
I got this phone used last week, fresh install with a certain rom (i dont know wich one, not sure how to tell, have no ideal how to get factory roms etc.) the phone is unlocked.
Before i plug in the usb to my phone, i enable debugging, then i select, USB mass storage.
WHen i connect i get the " Mac os X can't repair the disk "NO NAME"
then the External will mount, (so will the internal) here is what disk Util shows
It says the internal is 2.36 gb with 12.74 gb avail and only 980mb used, 0 number of files..
Now when i try to unmount the external, its fine, when i try to unmount the Internal, (NO NAME) all hell breaks loose, i wont let me, sometimes i get an error saying i cant unmount etc.. when i unplug it from the computer its still on my desktop, DiskUtil goes crazy and doesnt respond, then eventually any program that can see the drive will not respond (finder, activity Monitor)
anyone know a way around this? do i need to put a differnt install on it? its a t-mobile phone, should i just dl their newest update? how do i actually do that? their webpage? thanks for the help
j
j
