Help magic from vadafone
flax
Hello,
The HTC magic has following application:
* PDF Viewer
* Word
* Excel
* Capture video or stills
Is possible to install these application on Vodafone Magic or at least the PDF Viewer?
Thank you in advance.
Best regards,
Buy docs2go to allow;
edit/create word docs
edit/create Excel docs
View Pdfs (other pdf viewers are available)
As standard you Magic will be able to capture video and stills
Thank you for your answer. I read that Magic from Vodafone is able to get quicker an Android 2.0. If it is true then which version of Android is possible to get?
IIRC Android 2.1 is coming to the Magic some time soon.
If you don't want to wait you can run any version of android you want as long as you root the device and install a custom ROM. All of the 2.x ROMs running on the Magic do not support all the hardware, a typical example would be loss of camera or GPS support.
