Help Magic Internet problem
When the internet is changed from Wifi to no Wifi, it always takes a long time to switch back to 3g internet. If I restart the phone, the 3g internet can work properly.
Is it a known issue or is it because of some settings? Please advise. Thanks in advance.
Background information: I don't know if it is related or not. I am using "APNdroid" to control the on/off of 3G internet and "WeFi Connect" to control on/off of Wifi internet. I didn't do much on the setting of the phone, 3G internet and Wifi internet just set to be "on" by default.
Hi, My name is Omer, I am the mobile group manager at WeFi.
WeFi does not turn the 3G on or off so I find it hard to believe we have anything to do with this.
However, try to "Quit" WeFi Connect from the menu and see if things improve. If it does, I would appreciate if you would let us know, so we can keep improving WeFi.
You can also reach me at omer@wefi.com
Take care, and thank you for using WeFi Connect
Omer Paran.
