Help Main/Lock Screen is Dark and DIM
Crafter
Hey guys, wondering if you might be able to help before I go through the manufacturer...
I was listening to music using Winamp, I got a call. After I finished I unlocked the screen and it was very dim with weird colors. sorta like 8bit.
I did a hard reset (both from the setting menu and using the r key) still nothing.
update:
I couldn't take a screen shot because my phone was not rooted.
I contacted Samsung. They sent me a UPS return label, i boxed it up.. sent it in for free.
14 days total of switching to a crappy phone i got my Indulge back. They replaced the LCD screen and LCD component. They really were nice about it and did not question anything. My phone was never dropped but I did have a few good scratches on the sides indicating wear on the phone. Phones back and works great.
With all the crappy service I've been getting with my car dealership (Mitsubishi) this was a delightful experience.
same problem here. I disabled auto brightness and set it to a low setting and at times i would notice that it would be darker than usual. Id go to dispaly settings and someway somehow the brightness adjusted itself to the lowest setting. This has happened before multiple times even after rebooting the phone. idk if theres a fix for that or what.
If it's set to power saving mode it will always change back to a lower setting for the brightness.
Take it off power saving mode then adjust the brightness manually.
