Hello,
I am new to Android and have just started trying to build the calculator tutorial at the link below from the Android website:
http://cloud101.eu/blog/2012/03/10/android-introduction-to-a-simple-calculator/
When I have the xml code setup in the layout/main.xml file as in the tutorial, I get two errors and I'm not sure why. The errors are
Error parsing XML: junk after document element main.xml /Calculator_Android/res/menu line 11 Android AAPT Problem
and
The processing instruction target matching "[xX][mM][lL]" is not allowed. main.xml /Calculator_Android/res/menu line 11 Android XML Format Problem
I have included the code below and would be very grateful if someone could explain the problem with the code.
<menu xmlns:android="http://schemas.android.com/apk/res/android" >
<item
android:id="@+id/action_settings"
android
rderInCategory="100"
android:showAsAction="never"
android:title="@string/action_settings"/>
</menu>
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:layout_width="fill_parent"
android:layout_height="fill_parent"
android
rientation="vertical" >
<LinearLayout
android:id="@+id/linearLayoutH1"
android:layout_height="wrap_content"
android:layout_weight=".25"
android
android:weightSum="1" >
<EditText
android:id="@+id/result"
android:editable="false"
android:layout_weight=".50"
<EditText
android:id="@+id/entry"
</LinearLayout>
<LinearLayout
android:id="@+id/linearLayoutH3"
android:layout_height="100dp"
android
rientation="horizontal"
android:weightSum="1.0" >
<Button
android:id="@+id/buttonClear"
style="@style/ButtonText"
android:layout_width="0dp"
android:background="@drawable/custombuttonred"
android:text="@string/clear"
android:layout_weight=".43"
android:textSize="40sp" />
<ImageButton
android:id="@+id/c101_image"
android:scaleType="centerInside"
android:background="@drawable/cloud101"
android:layout_weight=".14" />
<Button
android:id="@+id/buttonBackspace"
android:text="@string/backspace"
android:textSize="30sp" />
</LinearLayout>
<LinearLayout
android:id="@+id/linearLayoutH2"
android:layout_height="50dp"
android
<Button
android:id="@+id/button1"
android:layout_width="50dp"
android:background="@drawable/custombutton"
android:text="@string/b1"
<Button
android:id="@+id/button2"
android:text="2"
<Button
android:id="@+id/button3"
android:text="3"
<Button
android:id="@+id/buttonDevide"
android:background="@drawable/custombuttonblue"
android:text="/"
</LinearLayout>
<LinearLayout
android
<Button
android:id="@+id/button4"
android:text="4"
<Button
android:id="@+id/button5"
android:text="5"
<Button
android:id="@+id/button6"
android:text="6"
<Button
android:id="@+id/buttonMult"
android:text="X"
</LinearLayout>
<LinearLayout
android:id="@+id/linearLayoutH4"
android
<Button
android:id="@+id/button7"
android:text="7"
<Button
android:id="@+id/button8"
android:text="8"
<Button
android:id="@+id/button9"
android:text="9"
<Button
android:id="@+id/buttonMinus"
android:text="-"
</LinearLayout>
<LinearLayout
android:id="@+id/linearLayoutH5"
android
<Button
android:id="@+id/button0"
android:text="0"
<Button
android:id="@+id/buttonDot"
android:text="."
<Button
android:id="@+id/buttonEq"
android:background="@drawable/custombuttongreen"
android:text="="
<Button
android:id="@+id/buttonPlus"
android:text="+"
</LinearLayout>
and
<item
android
rderInCategory="100"android:showAsAction="never"
</menu>
android
rientation="vertical" ><LinearLayout
android
rientation="vertical"android:weightSum="1" >
<EditText
<EditText
</LinearLayout>
<LinearLayout
android
rientation="horizontal"android:weightSum="1.0" >
<Button
<ImageButton
<Button
</LinearLayout>
<LinearLayout
android
<Button
<Button
android:text="2"
<Button
android:text="3"
<Button
android:text="/"
</LinearLayout>
<LinearLayout
android
<Button
android:text="4"
<Button
android:text="5"
<Button
android:text="6"
<Button
android:text="X"
</LinearLayout>
<LinearLayout
android
<Button
android:text="7"
<Button
android:text="8"
<Button
android:text="9"
<Button
android:text="-"
</LinearLayout>
<LinearLayout
android
<Button
android:text="0"
<Button
android:text="."
<Button
android:text="="
<Button
android:text="+"
</LinearLayout>
