Help Maintaining wifi link
Arbu
Member
I have a home wifi network to which I'd like my SF to connect automatically. But I keep having to go into Settings to get it to connect. I'm not sure but I think it disconnects whenever I go out or turn it off. How can I fix this?
Do you get the option to "remember" and you do tick yes?
Stating the obvious, but let's get you at least started :)
What router have you got and what encryption do you use, passworded at all?
lfc4ever, there's a password on my router but my phone remembers it OK. I just have to go into Settings/Wifi and re-enable the wifi with one press.
El Presidente I've downloaded your app, thanks. It sounds like it will work - I'll report back here if it doesn't.
