Maintenance and Care for android
jeebob
I have had my droid for a few weeks now, and have seen its starting to labour a little. So I need to look into cleaning it out already, possibly the installation of various apps, and things that load on startup...
So with Windows, I can enable or disable what apps start with the PC, I can clean out all old cache files, and various tools will remove a load of cack, and free up the space, amongst other things!
So, the question is, how do I look after my droid? Do you have any apps that I can use to clean my phone, and maintain the startup of apps etc?
I don't know if you are rooted, but this application can work on your device if its not rooted. http://20u5.qr.ai
Hopefully this is what you are looking for.
Install the application called 'Memory Task Cleaner' for maintenance and care of your android device. It is the top rated free from the play store.
Thanks for the suggestions thus far guys, unfortunately I am root free at this time, pending a lot of thinking to decide wether to go invalidate warranty or not!
Thanks Rush, I have the android assistant already, so glad to see I picked this one correctly! as for the memory task manager, thanks Colm will look at this one later!
Thanks
One of the biggest drains on battery and CPU are social media apps. If you have Facebook, Twitter, Myspace, LinkedIn, and other social media apps on your phone, all of then will be running in the background eating memory.
Another big drain comes from games that have suicidal components to them, b/c they, too, are running in the background.
Which phone do you have?
Hi john, I have the galaxy y, so not exactly hardware heavy, its a good little phone just need to learn its capabilities and care!
Hey, Jeejob, please explore this site for information about task killers, memory cleanup, etc. I believe you'll find that, in general, Android does not require such things and they just use more battery power while doing their thing. Android is very good at managing resources itself.
Hi Jim, thanks for the post, being new to the world of 'droids I have probably still a lot to learn!
at this moment, my RAM is 217 / 290, and after running a "clean" with go themes, its 168 / 290 and it will steadily increase even though sat for the most part idle...?
I am always happy to learn though, so any advice would be much appreciate...
In the time to type the last few sentences, my droid went into "idle" and on releasing the screenshot, my memory is now 189 / 290 :(
just left it again for 45 - 60 seconds, and now at 204 / 290...
I don't think you should worry about this in itself. Free RAM is wasted RAM - it's doing nothing for you. So if the RAM is filled by storing inactive apps that's not a problem. If you switch to one of those apps it's already loaded, so it saves battery compared with reloading it. And if the OS needs the space it will clear an inactive app out. This is what Jim is saying about task killers being counter productive.
With our phones, we have apps that are constantly receiving information via the data connection. It's not like a computer where you can simply turn off
Outlook and stop receiving email updates, for example. Our phones are set up to automate the prices, so they are always checking for new information in the background.
Furthermore, everything on your phone is an app. Your call log, dialer, SMS program, etc. are all apps. Fisher and SMS do not use the data connection, but separate 'cell' connections that are always sending info as well.
For your main apps, like Google's apps, plus things like social media apps, etc., the more you allow them to connect and check for updates, over time the more memory they will use. To minimize this, you'll want to check your Google account settings and remove / tweak as many of the sync settings to you're liking / needs add possible. That will help alleviate some if the usage.
The same applies to other apps, but those are normally handled within the app's settings dialog instead of the system settings.
For phone calls and SMS, the more you have the more is always loaded into memory. I use Call log backup and SMS Backup & Restore, both by Ritesh Sahu, to make backups and delete them out of the actual logs, which will help free up memory, particularly when you have hundreds of either.
HTH
Correct, to a point. While Android is better at memory management, there is a limit to what you can have running and still have an effective system. Being able to use the phone as it is designed sometimes means still manually checking things as i mentioned above in order to maximize the operating system's responsiveness. No matter how good the memory management is, you can still overload it so that even simple tasks like opening the app drawer take entirely too long.
While i don't believe in the effectiveness of regular use of task killers and such, i still keep one around b/c apps do get hung, needing intervention on my part to FC them. Especially on lower end devices, where active RAM is limited.
Hadron has it right - don't worry about processes or memory. Leave management of running processes and memory up to Android. It needs NO help doing that without additional apps or user intervention and does an excellent job. Use a minimum of widgets as they can cause problems.
IOW, relax and enjoy using your phone.
Thanks for all the suggestions guys, it looks to me like the best answer is going to be to roll the phone back to factory, then just put the minimum on that I need! rather than trying to load it to the max...
I guess its fair to say I didnt realise just how great a difference there is between Windows and android! I will have to start trusting my droid more than I do Windows! lol
