I have a Maipad Flytouch 3 DISCO 10 with the room Tim6a. From some days ago every time I switch on my Tablet it is in the same "status" it was on nov 15th.
I mean that:
- if I install new apps, when reboot the apps are not there
- if I remove some app, when reboot it is still there
- it makes the same updates of apps every time I switch on
- I changed my google password in my laptop, when I swith on the tablet it asks me for the password and I type it, but everytime I switch on I need to do this. It does not remember the change
- If I open the gmail the first list of emails are the ones I had on nov 15th, after a while it refreshes
Things I tried:
- reinstall same room or different: it does not allow me to reinstall any room. I tried and the process seems to run normally but after rebooting the old room is there with all the apps and the data.
- reset button: nothing
- back+home+power: nothing because the menu with the four options does not appear
- I searched for the Factory Default Settings, but the option Settings>Privacy does not exist on my Tablet...
I guess you can help me because I have no more ideas to try and right now a tablet without the possibility of updating apps or core data is not useful
Thank you in advance
I mean that:
Things I tried:
