Gentlemen,
I am opening this point because I have the issue with the making of the calls due to my disability. Simply you can imagine me as the guy without hands sitting on the wheelchair.
I am owner of Samsung Galaxy S3 and I need to find a way how to make a call without touching of my device outside of my house. I know that the phone has the application called S Voice which can be used when I am at home in the quiet environment with the access to the Internet. But this application does not work without the access to the Internet and in the noisy environment outdoor.
A few years ago I had a mobile phone based on Windows Mobile platform and all my issues of this kind has been resolved thanks to the following application: VITO Voice2go
This application has been using "magic word" for the starting of the voice recognition and the voice tags for the selected contacts. It was a big advantage because when I have set the voice tags only for a few contacts then there was a very high percentage of the correct recognitions.
Unfortunately I cannot find any similar application for Android and I would very appreciate if you can advice me some solution. But please keep in your mind that I cannot use my hands so Bluetooth solution is not a applicable.
Thanks a lot in advance.
