I want to make a 5 frame animation. I got five PNGs, named frame1,frame2,... and put them into the res folder.
I then created Bitmaps, and converted the Bitmaps into BitmapDrawables.
And then added them to an AnimationDrawable inside an ImageView (ImV).
Here is the code.
Unfortunately, all that happens is the first frame of animation bmp1 is shown. It doesn't cycle through the frames.
Could I get some advice how to do this properly?
Here is the code.
Bitmap bitmap1 = BitmapFactory.decodeResource(getResources(),
R.drawable.frame5);
Bitmap bitmap2 = BitmapFactory.decodeResource(getResources(),
R.drawable.frame4);
Bitmap bitmap3 = BitmapFactory.decodeResource(getResources(),
R.drawable.frame3);
Bitmap bitmap4 = BitmapFactory.decodeResource(getResources(),
R.drawable.frame2);
Bitmap bitmap5 = BitmapFactory.decodeResource(getResources(),
R.drawable.frame1);
BitmapDrawable bmp1 = new BitmapDrawable(bitmap1);
BitmapDrawable bmp2 = new BitmapDrawable(bitmap2);
BitmapDrawable bmp3 = new BitmapDrawable(bitmap3);
BitmapDrawable bmp4 = new BitmapDrawable(bitmap4);
BitmapDrawable bmp5 = new BitmapDrawable(bitmap5);
int duration = 100;
AnimationDrawable mAnim = new AnimationDrawable();
mAnim.addFrame(bmp1, duration);
mAnim.addFrame(bmp2, duration);
mAnim.addFrame(bmp3, duration);
mAnim.addFrame(bmp4, duration);
mAnim.addFrame(bmp5, duration);
ImV.setBackgroundDrawable(mAnim);
mAnim.setOneShot(false);
mAnim.start();
