Making Tasker revert changes when disconnected from Bluetooth
Hi all.
I'm trying to set up the ultimate car dock setup. When my Galaxy S4 is put in my car cradle, the NFC loads a Tasker profile, turning on Bluetooth, syncing to my car, loading up a car dock app, speed camera app running in the background, Wi-fi Off, Media Volume Up, Screen Timeout 23 hours etc...
This all works as planned, however, I want Tasker to undo all these changes once it no longer receives a Bluetooth signal i.e. when I turn the ignition off.
I've made an Exit task for my Bluetooth Connected profile, changing back all the relevant settings but nothing happens. I can see the Bluetooth icon unsyncing when the ignition is off but it doesn't change ANY settings at all. It also says no active profiles running even when it is most definitely working to switch everything on...
Any ideas or help please? Thank you :)
Thanks for the reply vsg. It wasn't, no. But I found out what I was doing wrong, instead of creating an exit task I selected a different type of exit task? I can't recall what now, but I've since heard I could've just selected "invert" to undo all my changes.
