Malty tuch zooming
PADL
Dear All
My Android tab OS version is 2.3, most of time I used for reading PDF file. for zoom the page I need touch two times. please advice me how may i zoom using two finger expanding ( I think malty touch)
Please advice
Dear vosg,
Thank you so much for reply
I need to confirm that malty touch support by hardware or software. my android tab does not support it,
Can you lease advice
Do you know the touchscreen technology? If it is resistive (has a thin layer over the screen that you press down onto the glass) then it won't support multi-touch.
Dear Hadron,
The Model Number is m799ca v2.0
The main reason is to update my TAB dose not support malty touch
Please advice
thanks in advance
