Malware? How to fix?
Resolute
My notification bar is getting pop ups for me to check out aps. How do I get rid of it? I am not very phone savvy. Thanks!
You've probably got some form of push advertising. If you get Addons Detector it will show you exactly which app is the culprit. Get rid of it and the ads go away.
There is a thread dedicated to airpush apps. OP, could you list it there once you ID the culprit?
