R reader Well-Known Member Mar 30, 2012 #1 hello! I want to be able to manage my 3G connection as I do my wifi connection (an immediately accessible button enables/disables it) how can I do this? thanks!
!on Android Expert Mar 31, 2012 #3 Yes you can find these things called "widgets" in the market. Some search terms for you to use: 3g 3g toggle data toggle 3g widget ... etc etc etc etc....
J jerofld Fixing stuff is not easy Mar 31, 2012 #4 Most devices have a built-in widget that will do this for you. On HTC devices, it's called "Mobile Network".
!on Android Expert Mar 31, 2012 #5 op asked for "an immediately accessible button" which sounds like a homescreen widget to me! ok i'll name one... APNdroid.... there's others I'm sure
