Help Maps Location
pilot221
Anyone have an idea on why Google Maps cannot find my location anymore? Happening since before the new update today, maybe 2 updates ago it started. It always thinks I'm at 'home' and continues to try to find me without any luck. Used to work flawlessly with wireless networks. Now it sometimes works with GPS, never with it off. If it does happen to work, it takes forever to find me where it used to instantly locate me. Takes away from the maps experience if you ask me.
Thanks
turn on your wifi then turn it back off after awhile it'll fix it.
for some reason it locks you to your last position or something with the new update... took me like 5 mins to figure it out at work.
I was getting ticked b/c i was looking for the 3d buildings :)
