Help Market Addresses not found
mkibrick
Member
Does anyone else have a problem with searching the market using the app address (I guess that's what it is called)? When I scan a barcode, I'm given a pname address, such as the article on Phandroid today had a barcode that gave me pname: com.mooapps.autolock. When I use Barcode Scanner to then search the Market, it is not found. I also could not find the Developers Challenge apps from Google's own link.
If you know the app exists, but it will not show up in the market on the Droid, it's because it is not compatible with 2.0/Droid.
