Help Market applications cauing problems
Hi,
Whenever I download or update something from the market it becomes unstable hangsup and then I have to remove the battery and restart. Already did hard reset three times but still problem not being solved. can the market application be corrupted.
Hi,
Market seems to be one of the wiggiest apps around ;)
The most often used remedy is to go into menu > settings > applications > manage applications and select Market, then clear everything that is not greyed out: cache, data and defaults, then reboot your device.
But if you're seeing problems across many apps downloaded from Market, I'd wonder about other things. If you're seeing a successful install in the notifications following downloading of an app, and there are still issues, especially more than one app, I'd be tempted to do a factory data reset to wash out whatever issue is causing that.
But I'd first try the Market "cleaning" and rebooting regimen. That may do the trick.
Thanks for the tip. I will try. The main problem is coming when I am trying to download two or three applications together. I have tried factory reset and all those two times. Intially I thought it was caused by some faulty application but then I noticed it comes only when I downlaod some thing from market.
