market issue not enough space
artcwolf
so i upgraded to 1.2 this morning. Now when i'm trying to update apps, or download new ones i'm getting the error "inefficient space on device" i've rebooted several times, I'm also working on restoring apps using TB, any help would be welcome thanks in advance.
Also some apps seem to be hanging when restoring with TB. Where's my Droid is one of them, another is rebooting my phone.
Use the option in music player to set ringtone
That's the option i'm looking for. I"m using Misic with the headphones icon. I've opened the file to play it and looked at options, and also long clicked to try and bring up the set as ringtone option and still can't find it. I know it's got to be something so simple i'm missing it.
just play the song which you want as ringtone while its playing than hit option long click wont help...it will use as ringtone
alternate
create notification folder in root of sd card and place mp3 file in it
go to settings>sounds>ringtone
it will be there in that
hit THANKS if helped
