Help Market Issue
w8-4-me
I know this is a known issue. I had the steps to fix this on my rooted Dx. Now that I have a Razr, i can't find the steps to fix it. Even after downloading an app from the market, when I check My Apps it says "apps and games owned by this account will appear here".
I have done searches on numerous sites and can't find anything pertaining to the Razr. I am not rooted and am on 2.3.6 (6.12.173). My Razr is also the XT912. Thanks in advance.
I'm not sure I completely understand your issue:confused:. Are you saying none of your apps show up in the market even after you download and install them?
You can try to clear data and cache from the Market. This works with a lot of Market issues.
Settings | Apps | All | Market and you should see the buttons there.
When I go to MY APPS in the market I get a white page that says "apps and games owned by this account will appear here". I have cleared data and cache a few times now. It hasn't helped. I just got the phone yesterday and am getting it set up. With the DX I had to kill market links and relink apps. Since I am not rooted, how do I fix this on the Razr?
Wait for me (I like it:D),
I'm at work right now, so am a little limited in digging for stuff. So if you don't hear back from me for a little bit, that is why. I am going to try and find you a solution. I have only ever logged in with my account and away I went.
