Root Market Issues
Needsdecaf
Android Expert
Hello:
I'm having issues with the market. I've tried to download several apps and updates over the last couple of days, but they are stalled on the "downloading" stage.
Running droid mod 1.0, I've reflashed and it's not making things better.
I had this issue on my Eris once but I can't recall what the solution was. I've tried clearing cache but that's not working either.
Any ideas?
Many times the problem is not on your end. When that happens it usually clears up on it's own after a few hours (once had to wait almost a day).
No, as I said, this has been happening for a while.
Finally figured out the culprit....startup auditor. And it was the same issue that I had last time this happened. Guess I got a little aggressive with what I killed.
mine seems to do that on wifi alot, i do not run atart up auditor so this could be a common problem, mine never last a day though, only 10 minutes or so.
