Market wifi problem
Arsonman
Nov 5, 2009
130
6
When I am connected to my home Wireless router I can not get into the Android Market. It says loading then just says "connection problems". If I turn off wifi it works fine. I have not tried this in any other hotspots. Is anyone else having this problem?
I think it probably has to do with the way the market works. If you go to the android market from your computer you can see some (not all) of the apps but you can only download them from your phone. If you are on wifi you are technically "not on your phone". This is a guess on my part but I would bet that's the issue.
Upvote 0
BEST TECH IN 2023
Smartphones
