Market won't work anymore
Hi,
I'm kinda new on rooting android phones.
I have a samsung galaxy ace phone running gingerbread.
I rooted my phone without any issues.
But then i installed the "titanium backup" app.
But in al my entousiasm about the fact it was working.
I forgot to backup first and...
I erased some google things. But now original navigation is gone.
And also my market app is broken.
In first case he asked me something about an account.
And then i tried to remove the updates.
And now when i start the market i just see a white screen flash.
And then its over again.
Isn't there any way i can repair this?
Any suggestions?
Thanks
Ok, not everything is working.
My connection seems not to work for the market.
It says:
"Can't establish a reliable data connection to the server"
Any ideas?
Now he comes up with the alert:
"The application Market (process com.android.vending) has stopped unexpectedly. Please try again."
And also
"The application Google services Framework (process com.google.process.gapps) has stopped unexpectedly. Please try again."
Isn't there anyway i can get the original goolge install files (.apk files) for the galaxy ace phone?
Can not find then even on google.
Grtz
OK, here's the situation. Those popup "error notifications" will happen sometimes, try not to worry about them. It's like a system/ software ongoing issue.(Clear data from the market app.) As for what you're asking for - I don't think you'll find that on the web. I'll look for it and PM it to you.
This is one of my old backups of Gapps when I had installed CM some months ago .Lost interest in CM it is lying particularly useless .
Maybe it will work . Maybe it wont .
Edit .
I dont know what version of bml recovery you are using .So rename it to update.zip .
Copy to sdcard
Reboot to recovery and use install from sdcard option .
I think i done to much...
Constantly the 'force close' and i even can't add a google acount anymore.
In case:
Is there any possible way i can totaly restore like i bought the device?
Or should Reflash the stock Firmware be enough( or is this resoring the phone )?
Grtz
You have answered your own question .
Flashing to stock firmware will restore your phone as you bought the device .
You can use Odin tutorials available in ATR thread .
Or goto Samsung Care who will flash it for you in half an hour
I downloaded a firmware file pakage, but it seems to be the wrong one.
How can i easely now which one is mine.
