Hi there,
I just got a new phone, its a chinese branded Elephone P9000, ive had it for a few days now and can't fault it other than the battery life is killing the phone, I don't think a full 24 hours is possible even on low usage!
I decided to do an experiment last night and I charged it fully before I went to bed and also switched the phone on. I left it throughout the entire night with screen off when I woke up about 9 hours later it has done about 55%! I look at the battery stats and it shows that something is keeping the phone awake.
I have attached the images showing this.
A thought I have now that I will try is maybe it is the new doze feature not working correct and i can turn this off on all apps by setting them to 'not optimized'. Do you think this could be something that would work?
This problem is bugging me and it seems a problem with Android Mashmallow as a quick google search on the battery drain issue comes up with many posts with similar issues.
Any suggestions guys....or gals
James
,James
