krishnaveni
I have developed one android application.
Here i have to add the maximum quantity is 5 to cart.
But i have wrote the condition is correct for these requirement.
I have to run the application means more product is added to cart.please help me.
please check my code and give me solution for these.
whats wrong in my code.please explain me.
[HIGH]
public class SingleMenuItem extends Activity {
static final String KEY_PNAME = "productName";
static final String KEY_PRICE = "productPrice";
static final String KEY_TOTAL = "total";
static final String KEY_QTY = "qty";
static final String KEY_THUMB_URL = "productImage";
private EditText edit_qty_code;
private TextView txt_total;
private TextView text_cost_code;
private double itemamount = 0;
private double itemquantity = 0;
String mTitle, mQty, mCost, mTotal;
int total_count;
@Override
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.single);
Button back = (Button) findViewById(R.id.back);
back.setOnClickListener(new OnClickListener() {
public void onClick(View v) {
Intent intent = new Intent();
finish();
Intent in = getIntent();
String title = in.getStringExtra(KEY_PNAME);
String thumb_url = in.getStringExtra(KEY_THUMB_URL);
String cost = in.getStringExtra(KEY_PRICE);
String total = in.getStringExtra(KEY_TOTAL);
ImageLoader imageLoader = new ImageLoader(getApplicationContext());
ImageView imgv = (ImageView) findViewById(R.id.single_thumb);
final TextView txttitle = (TextView) findViewById(R.id.single_title);
TextView txtheader = (TextView) findViewById(R.id.actionbar);
text_cost_code = (TextView) findViewById(R.id.single_cost);
edit_qty_code = (EditText) findViewById(R.id.single_qty);
edit_qty_code.setText("1");
txt_total = (TextView) findViewById(R.id.single_total);
txttitle.setText(title);
txtheader.setText(title);
text_cost_code.setText(cost);
txt_total.setText(total);
imageLoader.DisplayImage(thumb_url, imgv);
itemamount = Double.parseDouble(text_cost_code.getText().toString());
txt_total.setText(Double.toString(itemamount));
edit_qty_code.addTextChangedListener(new TextWatcher() {
public void onTextChanged(CharSequence s, int start, int before,
int count) {
// TODO Auto-generated method stub
if (!edit_qty_code.getText().toString().equals("")
|| !edit_qty_code.getText().toString().equals("")) {
itemquantity = Double.parseDouble(edit_qty_code.getText()
.toString());
.toString());
.toString(itemquantity * itemamount));
} else {
txt_total.setText("0.00");
public void beforeTextChanged(CharSequence s, int start, int count,
int after) {
public void afterTextChanged(Editable s) {
ImageButton mImgAddCart = (ImageButton) findViewById(R.id.img_add);
mImgAddCart.setOnClickListener(new OnClickListener() {
mTitle = txttitle.getText().toString();
mCost = text_cost_code.getText().toString();
mCost = mCost.replace("From ", "");
mTotal = txt_total.getText().toString();
mTotal = mTotal.replace("From ", "");
mQty = edit_qty_code.getText().toString();
if ( (Constants.mItem_Detail.size() <= 0)) {
HashMap<String, String> mTempObj = new HashMap<String, String>();
mTempObj.put(KEY_PNAME, mTitle);
mTempObj.put(KEY_QTY, mQty);
mTempObj.put(KEY_PRICE, mCost);
mTempObj.put(KEY_TOTAL, mTotal);
Constants.mItem_Detail.add(mTempObj);
total_count=total_count+Integer.parseInt(mQty);
else {
for (int i = 0; i < Constants.mItem_Detail.size(); i++) {
if (Constants.mItem_Detail.get(i).get(KEY_PNAME)
.equals(mTitle)) {
Constants.mItem_Detail.remove(i);
break;
} else {
if (total_count <= 5) {
AlertDialog.Builder alertdialog = new AlertDialog.Builder(
SingleMenuItem.this);
alertdialog.setTitle(getResources()
.getString(R.string.app_name));
alertdialog.setMessage("Add in ViewCart");
alertdialog.setPositiveButton("OK",
new DialogInterface.OnClickListener() {
@Override
public void onClick(DialogInterface dialog,
int which) {
//finish();
return;
alertdialog.show();
ImageButton mImgViewCart = (ImageButton) findViewById(R.id.img_view);
mImgViewCart.setOnClickListener(new OnClickListener() {
@Override
Intent mInViewCart = new Intent(SingleMenuItem.this,
ViewCartActivity.class);
mInViewCart.putExtra("Title", mTitle);
startActivity(mInViewCart);
[/HIGH]
[HIGH]
int total_count;
@Override
finish();
int count) {
.toString());
.toString());
} else {
int after) {
else {
.equals(mTitle)) {
break;
} else {
@Override
int which) {
//finish();
return;
alertdialog.show();
@Override
[/HIGH]
