maxing out brightness during incoming call
kkudi
Member
Trying to do this with Tasker on the S3 but I'm failing.
Anyone has any input?
I've used the following:
New Profile -> State -> Phone -> Call -> Incoming
New Task -> New Action -> Display -> Display Brightness -> Level 255
I've also tried New Profile -> Event -> Phone -> Phone Ringing
But neither of them worked.
Any suggestions?
Do you have autobrightness set? When you press play on the task, does the brightness change?
Can you call your phone from another and check if the profile becomes active (goes green) when it should?
I've found the root of the problem again. It's Lux. Anyone knows how to solve the problem without having to disable Lux?
