Help May u please help me for the following issues
May u please help me for the following issues - in my note 2 when I download any songs from internet after 2 seconds it display not enough space and download unsuccessful please help
I have moved your post on it's own for proper help and support, cheers.
Hello and welcome, sahilthakur.
What else do you have in internal storage (sdcard0) that can be moved to your external sd card (extsdcard)? Pics, etc? This will make room for media.
Have a look in your file manager (the stock one is called "my files"). Select "all files" first, then "sdcard0" to see what is taking up storage space there. Some of it can be moved off to the removable sd card.
Well first of all thanks Donb and Frisco for replying to my query.i have attached the screenshot of my storage and this is my new fone I got it just 2 days back, I downloaded two songs but now I have issues with every download. Am using wifi at home.
Hello again. Please use your file manager ("my files" app) to analyse the contents of your internal storage for items that can be moved to your external sd card.
I changed the directory to external sdcard by going into myfiles and I have attached the screensgot to you. I think this is what you meant.
Hi
That is the settings in my files. It just changes where the shortcuts on the my files start page point to. It does not change where the phone saves anything. To do that you need to enter each app, camera etc, and change the storage location in the apps own settings.
First you need to find out what has filled up your sdcard0 folder. Have you synced your phone with a big cloud folder such as Dropbox which has downloaded all your o old photos to your phone and filled it up?
