sagishwartz
Hi,
Just bought the measy a5a and I can't install it,
I have sdcard 2G with fat32 I copied the latest image to the card with the name "update.img", I followed the procedure:
1.download the software , decompress the compression file and get the Update.img file , and put the Update.img file into SD card
2.plug the SD card into A5A SD card slot , connect A5A with TV and adapt,make sure it turn on
3. upgrade the A5A according to the indirection which you see on TV screen
and nothing happens, in addition i tried to install it from my pc with the program RKBatchTool 1.3 but my win7 64bit doesn't recognize my measy a5a
Can somebody please help me?
Thanks
Thanks
