Hi.
I'm going on a trip and hoping to bring as little gear as possible. I'm trying to see if I can take the MicroSD card out of my camera and pop it in one of these:
memory card reader 5-1 on eBay
to backup the family pics at the end of each day.
Questions:
1)will it work
2)would I mount that manually(not a problem) or will it automount. If so, where?
3)I'm very familiar with linux and would fancy rsync over any other method. I presume if 2) is yes then rsync shouldn't be an issue. However, has anyone had any experience(s) that would defer from what one would expect?
Any other comments/questions are welcome...Just don't tell me to use Windows
Thanks in advance, Phil.
EDIT: forgot to enquire about the whole Samsung 5 pin / 11 pin issue. Would that be relevant here?
Questions:
1)will it work
... if you haven't apps with a huge amount of data like offline navigation and offline dictionaries. They've still their GBs on the external SD card (okay ... I admit, you can choose the storage
backup plan is what GTWalling suggested. Put the card in the phone and sink to the cloud.
