Help mediaserver draining battery
Ewoedo
So I woke up this morning to find my battery had drained quite a bit overnight. Around 15% when it normally doesn't drain at all. Going to see the issue I saw there was a lot of awake time:
Mediaserver was the issue. What could be causing this?
Ps. It wasn't downloading the update you can see in my notification bar. That was done ages ago, I just haven't got around to doing it.
Sure. Ill try an SD format and then a factory reset after I backuo my stuff, and post back.
