MEEP! X2 discontinued product how use piano accessory ?
what do you mean piano accessory? is that an app for the phone? are you saying that the apps you want are not compatible with your phone?
you can try searching for an apk for the app you are looking for. just keep in mind that if yiou do find an apk file for your app. it might not work well with your phone. there is a reason you can't download the app on your phone. you can also try and contact the developers and see if they can port their app for your phone.
I believe Meep products have been completely discontinued by Oregon Scientific. If their supporting apps are no longer on Play or Amazon, probably only thing to try is Googling for them, or hoping that someone reading this thread still has it?
"piano accessory" was a musical keyboard that Oregon Scientific made wasn't it, to go with their Meep series tablets?
Hello, as you can see I posted in the digital tablets section, so the "MEEP! x2" is a tablet under Android 4.2 operating system with a software overlay that limits access to its functions and requires the use of applications available only from the manufacturer's website but problem the manufacturer no longer offers the new product and the website has been closed and the store for applications. The accessory is a flexible piano keyboard designed exclusively for this tablet and if you do not have the associated application installed in the tablet the accessory is unusable, note that the shop that provided the application having been disabled / offline it is impossible to obtain the application needed to use this piano keyboard (accessory). So I'm looking for help to make this accessory usable with the tablet in question.
Translated with www.DeepL.com/Translator
Bonjour, comme vous le constatez j'ai posté dans la rubrique tablettes numériques, donc la "MEEP! x2" est une tablette sous système d'exploitation android 4.2 comportant une surcouche logicielles qui limite l’accès aux fonctions de celle-ci et impose l'utilisation des applications disponibles uniquement depuis le site internet du fabricant mais problème le fabricant ne propose plus le produit en neuf et le site internet à été fermé ainsi que la boutique pour les applications. L'accessoire est un clavier de piano souple conçu exclusivement pour cette tablette et si on ne possède pas l'application associées installée dans la tablette l’accessoire est inutilisable, notez que la boutique qui permettais d'obtenir l'application ayant été mise hors service / hors ligne il est impossible de se procurer l'application nécessaire à l'utilisation de ce clavier de piano (accessoire). Donc je cherche de l'aide pour rendre utilisable cet accessoire avec la tablette en question.
