D
Deleted User
Guest
Als ik het belletje,stille modus aantik om uit te zetten hoor ik een meldings toon,hoe zet ik dat uit??
not sure i understand your question. you push the "bell" to turn silent mode off. when you do so the phone makes a notification sound, is that correct?When I tap the bell, silent mode to turn it off, I hear a notification tone, how do I turn that off??
again this is an english only site...use google translate. just type in your question in your language and then copy and paste the translation.Klopt helemaal,bij inschakelen niet,maar bbij uitschakelen wel
hmmmm well i do not have your phone so i can't completely troubleshoot your specific issue. but does your phone make other sounds when you select certain functions? what about selecting vibrate?Completely correct, not when switched on, but when switched off it is
Guunter gleeben globen goven.
